2004 - 2005 Cadillac XLR: Service Bulletin: Starts w/o Brake Input and Hard to Shift out of Park
Estimated Reading Time: 1 Minutes#PIC3079: 04-05 Cadillac XLR and 05 Chevrolet Corvette Starts w/o Brake Input and Hard to Shift out of Park, DTC C0161 - ABS brake BTSI switch code DTC key keyless park pedal remote RKE start - (Aug 4, 2004)
Subject: | 2004 - 2005 Cadillac XLR and 2005 Chevrolet Corvette Starts without Brake Input and Hard to Shift Out of Park DTC C0161 |
- Some customers may state that the vehicle will start without depressing the brake pedal and/or the shifter is difficult to move from the park position. This also may be followed by a ABS light with a DTC C0161. The customer may state that the concern happened after the vehicle was in for service for a brake switch or Body Control Module repair.
- Brake pedal position sensor calibration must be performed after the brake pedal position sensor or Body Control Module (BCM) have been serviced. When performing the brake calibration, if the brake pedal is depressed while performing the procedure, the symptoms listed above may occur. When performing a brake pedal position sensor calibration, it is critical that the steps listed in SI are followed.
- Models:
- (2004-05 Cadillac XLR) and (2005 Chevrolet Corvette)
