Service Bulletin #:  06-02-35-002
Date: January 2006
Subject:  Diagnostic Trouble Code (DTC) C0710 Steering Wheel Position Sensor (SWPS) Signal, Service Stability System Message on Driver Information Center (DIC) (Inspect and Secure Wires in SWPS Connector)
Model(s):
2005 - 2006 Chevrolet Corvette
with Steering Wheel -- Tilt, Telescoping (RPO N37)
Attached below is the PDF document for this service bulletin.
06-02-35-002
Article ID: 95
Created: December 25, 2016
Online URL: https://www.xlr-net.com/knowledgebase/article/2004-2006-cadillac-xlr-service-bulletin-diagnostic-trouble-code-dtc-c0710-steering-wheel-position-sensor-swps-signal-service-stability-system-message-on-driver-information-center-dic-95.html
