March 17, 2003: 2004 Cadillac XLR Specifications
FOR RELEASE: March 17, 2003
SPECIFICATIONS
Overview | |
Body style / driveline: | two-door, hardtop convertible / rear-wheel drive |
Construction: | hydroformed perimeter frame, structural center tunnel, aluminum cockpit frame |
Body material: | composite exterior panels |
Manufacturing location: | Bowling Green, Kentucky |
Key competitors: | Mercedes-Benz SL500, Lexus SC430, Jaguar XK8 |
Engine | |
Type: | 2004 Northstar RWD 4.6L V-8 |
Displacement (cu in/cc): | 279 / 4565 |
Bore & stroke (in/mm): | 3.66 x 3.31 / 93 x 84 |
Block material: | cast aluminum |
Cylinder head material: | cast aluminum |
Crankshaft material: | forged steel |
Valvetrain: | DOHC, four valves per cylinder, four-cam continuously variable valve timing |
Ignition system: | coil-on-plug ignition, with extended-life dual platinum-tipped spark plugs |
Fuel system: | sequential electronic fuel injection |
Compression ratio: | 10.5:1 |
Horsepower (hp/kw @ rpm): | 320 / 239 @ 6400 |
Torque (lbs-ft / Nm @ rpm): | 310 / 420 @ 4400 |
Recommended fuel: | unleaded premium |
Max. engine speed (rpm): | 6700 |
Estimated fuel economy (mpg city / hwy) |
17/24 (est.) |
Transmission | |
Type: | Hydra-Matic 5L50-E rear-wheel drive, electronically-controlled five-speed automatic with torque converter clutch and Driver Shift Control |
Gear ratios (:1): | |
3.45 |
2.21 |
1.60 |
1.00 |
0.76 |
3.02 |
2.93 |
Chassis/Suspension | |
Front: | short/long arm (SLA) double wishbone, cast aluminum upper & lower control arms, transverse-mounted composite leaf spring, monotube shock absorber |
Rear: | Short/long arm (SLA) double wishbone, cast aluminum upper & lower control arms, transverse-mounted composite leaf spring, monotube shock absorber |
Steering type: | Magnasteer power-assisted rack-and-pinion |
Steering ratio: | 17.2:1 |
Turning diameter, curb to curb (ft / m): |
39 / 11.9 |
Brakes | |
Type: | power-assisted disc with 4-channel ABS, front and rear |
Rotor diameter x thickness (in / mm): |
front 12.8 x 1.3 / 325 x 32 rear 12.0 x 1.0 / 305 x 26 |
Wheels/Tires | |
Wheel type and size: | spun-cast aluminum, 18 inch (457 mm) |
Tires: | Michelin ZP Extended Mobility front: P235/50R18 rear: P235/50R18 |
Dimensions | |
Exterior | |
Wheelbase (in / mm): | 105.7 / 2685 |
Overall length (in / mm): | 177.7 / 4513 |
Overall width (in / mm): | 72.3 / 1836 |
Overall height (in / mm): | 50.4 / 1279 |
Track (in / mm): | front 62.2 / 1580 rear 62.2 / 1580 |
Minimum ground clearance (in / mm): |
6.61 / 168 |
Curb weight (lbs / kg): | 3643 / 1653 |
Interior | |
Seating capacity (front / rear): |
2 / 0 |
Head room (in / mm): | 37.6 / 955 |
Leg room (in / mm): | 42.64 / 1083 |
Shoulder room (in / mm): | 54.3 / 1380 |
Hip room (in / mm): | 53 / 1346 |
Capacities | |
Cargo volume (cu ft / liters): | |
11.6 / 328 |
4.4 / 125 |
Fuel tank (gals / liters): | 18.0 / 68.1 |
Engine oil (qts / liters): | 10 / 9.5 5W30 Mobil 1 |
Performance | |
0-60 mph acceleration: | 5.9 sec. |
Max. lateral acceleration: | 0.90g |
