2004 - 2009 Cadillac XLR: Service Bulletin: #PIC4858A: Navigation Radio CD Error - CD Player Will Not Accept Discs - (Feb 11, 2013)
Subject Navigation Radio CD Error - CD Player Will Not Accept Discs
Models 2004-2009 Cadillac XLR
This PI was superseded to update the photos. Please discard PIC4858.
Some customers may comment that the CD changer (CDX) will not accept CD’s or the display shows a "CD Error" message when attempting to play a disc. This will usually occur after the radio or CD changer was recently serviced for a different customer's concern.  This may be caused because the ″shipping pin″ was not removed from the bottom of the CD changer prior to installing the service part into the vehicle.
2004 - 2009 Cadillac XLR Radio
Remove the shipping pin from the bottom of the CD changer prior to installing into the vehicle. This item is called out by an arrow in the first picture below.  The second picture shows the shipping plug that has already been removed from the CD changer.
If returning the Navigation radio to the Electronic Service Center, be sure to reinstall the shipping pin to prevent damage to the unit while in transit.
Viewed 337 times since Tue, Jan 10, 2017
2004 - 2009 Cadillac XLR: GM TechLink: No Fob Detected Message
Viewed 156 times since Tue, Dec 20, 2016
2008 Cadillac XLR: Service Bulletin: Change in the GM Nav Disc Update Program
Viewed 211 times since Tue, Dec 20, 2016
Viewed 146 times since Tue, Dec 20, 2016
Viewed 29 times since Tue, Mar 14, 2017
2004 - 2009 Cadillac XLR: Service Information: Head-Up Display Conditions
Viewed 176 times since Wed, Dec 21, 2016
Viewed 178 times since Sun, Dec 25, 2016
Viewed 117 times since Tue, Dec 20, 2016
Viewed 130 times since Sun, Dec 18, 2016
