2004 - 2009 Cadillac XLR: Service Bulletin: Diagnostic Tip - Difficulty Programming Modules, Cannot Achieve Ignition On, Engine Off Mode
#PIC3520C: Diagnostic Tip - Difficulty Programming Modules, Cannot Achieve Ignition On, Engine Off Mode - (Nov 2, 2015)
Subject: Diagnostic Tip - Difficulty Programming Modules, Cannot Achieve Ignition On, Engine Off Mode
Models: 2005 - 2011 Cadillac STS
This PI was superseded to update Model Years. Please discard PIC3520B.
Some technicians may experience failed module programming or difficulty performing certain diagnostic procedures due to the ignition not being in the "Ignition On, Engine Off" mode. The vehicles listed in this PI use a keyless access system with push button start.
To reach the "Ignition On, Engine Off" mode, press and hold the ACC/OFF portion of the Start/ACC/OFF mode button for 5 seconds with a valid keyless entry transmitter inside the vehicle and the transmission in Park (Auto Trans) or Neutral (Man Trans).
2004 - 2009 Cadillac XLR: Bose Sound System
Viewed 346 times since Tue, Dec 20, 2016
Viewed 184 times since Wed, Mar 22, 2017
2004 - 2005 Cadillac XLR: Service Information: Low or Completely Discharged Battery
Viewed 233 times since Sun, Dec 25, 2016
Viewed 100 times since Tue, Mar 14, 2017
Viewed 272 times since Tue, Dec 20, 2016
Viewed 180 times since Sun, Dec 18, 2016
Viewed 164 times since Sun, Dec 18, 2016
Viewed 309 times since Sun, Dec 25, 2016
Viewed 112 times since Tue, Mar 14, 2017
