Subject IPC Odometer Programming Method Quick Reference Guide
Models 2017 and Prior GM Passenger Cars and Trucks
Attention This Bulletin applies to vehicles sold in the U.S. and Canada Only.
This Bulletin has been revised to update the Chevrolet Aveo and Pontiac G3 information. Please discard Corporate Bulletin Number 07-08-49-020K.
The purpose of this bulletin is to provide a reference guide to help identify which season odometer programming method to use after replacing the instrument panel cluster (IPC). The three season odometer programming methods in use today are listed below. In addition, this reference guide lists the component where the season odometer value is stored. The season odometer value may be stored in the IPC, the driver information center (DIC) or the integrated body control module (IBCM), also commonly called a body control module (BCM).
Season Odometer Programming Methods in Use Today
  1. IPC reprogramming and setup using the service programming system (SPS).
  2. Odometer setup at the electronic service center (ESC) when using an exchange IPC/DIC.
  3. Tech 2® – The Tech 2 is used to set up a replacement BCM, which includes loading the odometer value that is displayed and stored in the IPC. A replacement IPC will display the previously stored vehicle odometer value, communicated from the BCM, after cycling the ignition or driving the vehicle.
    *The odometer programming is integrated as part of the BCM programming procedure. It is not a stand-alone event.
    Note: Stable battery voltage is critical during programming. Any fluctuation, spiking, over voltage or loss of voltage will interrupt programming. When required install the EL-49642 SPS Programming Support Tool to maintain system voltage. If not available, connect a fully charged 12 V jumper or booster pack disconnected from the AC voltage supply. DO NOT connect a battery charger.
Model
Model Year
Odometer Value Storage
Buick
Cascada
2016-2017
BCM
SPS*
Century
2003-2005
IPC
ESC
Enclave
2008-2017
IPC
ESC
Encore
2013-2017
BCM
SPS*
Envision
2016-2017
BCM
SPS*
LaCrosse/Allure
2005-2009
IPC
ESC
LaCrosse
2010-2017
BCM
SPS*
Lucerne
2006-2011
IPC
ESC
LeSabre
2003-2005
IPC
ESC
Park Avenue
2003-2005
IPC
ESC
Rainier
2004-2007
IPC
SPS
Regal
2003-2004
IPC
ESC
2011-2017
BCM
SPS*
Rendezvous
2003-2007
IPC
ESC
Terraza
2005-2007
IPC
ESC
Verano
2012-2017
BCM
SPS*
Cadillac
ATS
2013-2017
BCM
SPS*
CTS
2003-2007
IPC
ESC
CT6
2016–2017
BCM
SPS*
CTS Coupe, CTS Wagon, CTS-V
2008–2013
IPC
ESC
CTS Sedan, CTS-V
2014–2017
BCM
SPS*
DeVille
2003-2005
IPC
ESC
DTS
2006-2011
IPC
ESC
ELR
2014–2016
BCM
SPS*
Escalade
2003-2014
IPC
SPS
Escalade
2015-2017
BCM
SPS*
Seville
2003-2004
IPC
ESC
SRX
2004-2009
IPC
ESC
2010-2016
IPC
SPS*
STS
2005-2011
IPC
ESC
XLR
2004 - 2009
IPC
ESC
XTS
2013-2017
BCM
SPS*
XT5
2017
BCM
SPS*
Chevrolet
Astro
2003-2005
IPC
ESC
Avalanche
2003-2013
IPC
SPS
Aveo
2004-2008
IPC
ESC
2009-2011
IPC
SPS
Blazer
2003-2005
IPC
ESC
Bolt EV
2017
BCM
SPS*
Colorado
2004-2011
IBCM
Tech 2
Colorado
2012-2017
BCM
SPS*
Camaro
2010-2017
BCM
SPS*
Captiva Sport
2012-2013
IPC
SPS
Cavalier
2003-2005
IBCM
Tech 2
City Express
2016–2017
BCM
SPS*
Cobalt
2005-2010
IBCM
Tech 2
Corvette
2003-2013
IPC
ESC
2014–2017
BCM
SPS*
Cruze
2010-2017
BCM
SPS*
Epica
2004-2006
IPC
ESC
Equinox
2005-2006
IBCM
Tech 2
2007-2009
IPC
ESC
2010-2017
BCM
SPS*
Express
2003-2017
IPC
ESC
HHR
2006-2011
IBCM
Tech 2
Impala Limited (VIN W)
2003-2016
IPC
ESC
Impala (VIN 1)
2014–2017
BCM
SPS*
Kodiak
2003-2009
IPC
ESC
Malibu
2003
IPC
ESC
2004-2011
IBCM
Tech 2
2012-2017
BCM
SPS*
Monte Carlo
2003-2007
IPC
ESC
Optra
2004-2007
IPC
ESC
Orlando
2011-2014
BCM
SPS*
S-10
2003-2004
IPC
ESC
Silverado Classic
2003-2007
IPC
SPS
Silverado HD
2007-2017
IPC
SPS
Silverado LD
2007-2013
IPC
SPS
2014–2017
BCM
SPS*
Sonic
2012-2017
BCM
SPS*
Spark
2013-2017
BCM
SPS*
SS
2014–2017
BCM
SPS*
SSR
2003-2006
IPC
ESC
Suburban
2003-2014
IPC
SPS
Suburban
2015-2017
BCM
SPS*
Tahoe
2003-2014
IPC
SPS
Tahoe
2015-2017
BCM
SPS*
TrailBlazer
2003-2009
IPC
SPS
Traverse
2009-2017
IPC
ESC
Trax
2013-2017
BCM
SPS*
Uplander
2005-2009
IPC
ESC
Venture
2003-2005
IPC
ESC
Volt
2011-2017
BCM
SPS*
GMC
Acadia
2007-2016
IPC
ESC
Acadia Limited
2017
IPC
ESC
Acadia
2017
BCM
SPS*
Canyon
2004-2011
IBCM
Tech 2
2012-2017
BCM
SPS*
Envoy
2003-2009
IPC
SPS
Jimmy
2003-2005
IPC
ESC
Safari
2003-2005
IPC
ESC
Savana
2003-2017
IPC
ESC
Sierra Classic
2003-2007
IPC
SPS
Sierra HD
2007-2014
IPC
SPS
Sierra HD
2015-2017
BCM
SPS*
Sierra LD
2007-2013
IPC
SPS
2014–2017
BCM
SPS*
Sonoma
2003-2004
IPC
ESC
Terrain
2007-2009
IPC
ESC
Terrain
2010-2017
BCM
SPS*
TopKick
2003-2010
IPC
ESC
Yukon
2003-2006
IPC
SPS
2007–2014
IPC
SPS
2015-2017
BCM
SPS*
HUMMER
H2
2003-2007
IPC
SPS
2008-2010
IPC
ESC
H3
2006-2010
IBCM
Tech2
Oldsmobile
Alero
2003-2004
IPC
ESC
Bravada
2003-2004
IPC
SPS
Silhouette
2003-2004
IPC
ESC
Pontiac
Aztek
2003-2005
IPC
ESC
Bonneville
2003-2005
IPC
ESC
G3
2009-2010
IPC
SPS
G5
2007-2010
IBCM
Tech 2
G6
2005-2009
IBCM
Tech 2
G8
2008-2009
IPC
SPS
Grand Am
2003-2005
IPC
ESC
Grand Prix
2003-2008
DIC
ESC
GTO
2004-2006
IPC
ESC
Montana
2003-2005
IPC
ESC
Montana SV6
2005-2009
IPC
ESC
Pursuit
2005-2006
IBCM
Tech 2
Solstice
2006-2010
IBCM
Tech 2
Sunfire
2003-2005
IBCM
Tech 2
Torrent
2006
IBCM
Tech 2
2007-2010
IPC
ESC
Vibe
2003-2010
IPC
ESC
Wave
2005-2008
IPC
ESC
Saab
9-7X
2005-2009
IPC
SPS
Saturn
ASTRA
2008-2009
IPC
SPS
AURA
2007-2009
IBCM
Tech 2
ION
2003-2007
IBCM
Tech 2
L-Series
2003-2005
IBCM
Tech 2
OUTLOOK
2007-2010
IPC
ESC
RELAY
2005-2007
IPC
ESC
SKY
2007-2010
IBCM
Tech 2
VUE
2003-2007
IBCM
Tech 2
2008-2010
IPC
SPS
Viewed 169 times since Fri, Dec 30, 2016
2004 - 2009 Cadillac XLR: GM TechLink: No Fob Detected Message
Viewed 76 times since Tue, Dec 20, 2016
Viewed 62 times since Sun, Dec 18, 2016
Viewed 122 times since Sun, Dec 25, 2016
Viewed 374 times since Fri, Dec 30, 2016
2006 Cadillac XLR: Service Information: High Mount Stop Lamp Replacement
Viewed 97 times since Tue, Dec 20, 2016
2008 Cadillac XLR: Service Bulletin: Change in the GM Nav Disc Update Program
Viewed 82 times since Tue, Dec 20, 2016
Viewed 60 times since Sun, Dec 18, 2016
Viewed 90 times since Sun, Dec 18, 2016
Viewed 65 times since Tue, Dec 20, 2016
