2004 - 2009 Cadillac XLR: Bose Sound System
The Bose® Sound System for the Cadillac XLR:
9 high-performance speakers
  1. Two 8-cm mid-high-range speakers in the instrument panel.
  2. One 8-cm mid-high-range speaker (centrefill) in the instrument panel.
  3. Four 5-cm mid-high-range speakers in the backrests of the seats.
  4. Two 25-cm Nd® woofers in the doors.
System electronics
Digital amplifier mounted in the instrument panel. Includes Bose digital signal processing, AudioPilot® noise compensation technology, TrueSpace™ technology and 7 channels of customised equalisation.
AudioPilot® microphone mounted in the instrument panel monitors interior noise level.
See attachment below:
cadillac_xlr_en_tcm55-6173
Viewed 269 times since Tue, Mar 21, 2017
Viewed 273 times since Tue, Mar 14, 2017
Viewed 363 times since Sun, Dec 18, 2016
2004 - 2009 Cadillac XLR: Service Bulletin: Red LED and B2455 After Performing Canada Upgrade Bulletin 15-08-44-001
Viewed 357 times since Sun, Dec 18, 2016
Viewed 337 times since Tue, Mar 14, 2017
Viewed 616 times since Tue, Jan 10, 2017
Viewed 421 times since Tue, Dec 20, 2016
Viewed 210 times since Tue, Mar 14, 2017
Viewed 750 times since Sun, Dec 18, 2016
