2004 - 2008 Cadillac XLR: TechLink Article: Door Handle Release Button
Some owners of a 2004 - 2008 Cadillac XLR or Corvette may comment that the inside door handle release button switch will not release either the driver or passenger door. Verify that the door lock is not on. Further investigation will show that the door will function from the release handle/cable on the floor next to the inside rocker panel. This may be the result of
a stuck Exterior Door Handle Switch (touch pad) on the outside of the vehicle's door.
Monitor the status of the Exterior Driver or Passenger Door Handle Switch. This data can be viewed using the Tech 2 in the Driver and/or Passenger door module. If the status displays Active when the switch is NOT being depressed, inspect and repair any associated wiring.
If no trouble is found with the wiring, replace the Exterior Door Handle Switch as necessary.
- Thanks to Dino Poulos
January 2008 - GM TechLink
Viewed 130 times since Sun, Dec 18, 2016
Viewed 190 times since Tue, Dec 20, 2016
Viewed 117 times since Tue, Dec 20, 2016
Viewed 226 times since Sun, Dec 25, 2016
Viewed 147 times since Tue, Dec 20, 2016
2009 Cadillac XLR: GM Tech Link: Bluetooth Issues
Viewed 156 times since Tue, Dec 20, 2016
Viewed 45 times since Tue, Mar 21, 2017
Viewed 64 times since Tue, Mar 14, 2017
Viewed 254 times since Sun, Dec 18, 2016
Viewed 47 times since Wed, Mar 22, 2017
