Subject:  Intermittent Poor and/or No Radio Reception FM Stations
Models:  2004 - 2006 Cadillac XLR
This PI was superseded to update recommended field. Please discard PIC3865A.
Static may be heard on stations with an otherwise strong signal or unable to stop at specific stations when using the "seek" function. This concern will be noticed when the vehicles ignition is turned on and the FM band is the band displayed on the radio from the previous ignition cycle. When the reception is poor, changing the radio band from FM to AM then back to FM typically corrects this concern.
If the reception does not correct itself when changing bands, Strategy Based Diagnostic should be followed.
If the reception does correct itself when changing bands as described above, replace the Radio Antenna Module located on the right side of the deck lid.
