Service Bulletin #:  06-02-35-002
Date: January 2006
Subject:  Diagnostic Trouble Code (DTC) C0710 Steering Wheel Position Sensor (SWPS) Signal, Service Stability System Message on Driver Information Center (DIC) (Inspect and Secure Wires in SWPS Connector)
Model(s):
2005 - 2006 Chevrolet Corvette
with Steering Wheel -- Tilt, Telescoping (RPO N37)
Attached below is the PDF document for this service bulletin.
06-02-35-002
2005 - 2008 Cadillac XLR: TechLink Article: Fob Conditions
Viewed 755 times since Tue, Dec 20, 2016
Viewed 792 times since Tue, Dec 20, 2016
Viewed 1085 times since Sun, Dec 25, 2016
Viewed 948 times since Fri, Dec 30, 2016
Viewed 686 times since Sun, Dec 18, 2016
Viewed 1287 times since Sun, Dec 18, 2016
Viewed 516 times since Tue, Mar 14, 2017
2006 Cadillac XLR: Service Bulletin: Language Change for OnStar System (U.S. Only)
Viewed 729 times since Tue, Dec 20, 2016
2004 - 2009 Cadillac XLR: Service Bulletin: #PIC5335A: Composite Transverse Spring Damage - (Dec 13, 2012)
Viewed 502 times since Tue, Mar 14, 2017
Viewed 838 times since Fri, Dec 30, 2016
