2004 - 2005 Cadillac XLR: Service Information: No Crank, PRNDL Inoperative
Owners of some 2005 Chevrolet Corvettes and 2004 - 05 Cadillac XLRs may experience a no-crank condition, with no codes in any module. The concern may be followed by an inoperative transmission range indicator (PRNDL). The Tech 2 will show the transmission range circuits are all reading high when any gear is selected.
Check for a loose or broken ground G402 at the right rear suspension cradle. See SI document 1495107.
- Thanks to Paul Radzwilowicz, GM Techlink, July, 2005
2004 - 2009 Cadillac XLR: GM TechLink: No Fob Detected Message
Viewed 709 times since Tue, Dec 20, 2016
2006 - 2009 Cadillac XLR XLR-V: Service Bulletin: #16-NA-130: No Reverse, No Second After Upper Valve Body Replacement
Viewed 480 times since Sun, Dec 18, 2016
2006 Cadillac XLR-V: Service Bulletin: Automatic Transmission, Busy Shifting, MIL Illuminated, DTC P1751
Viewed 451 times since Tue, Dec 20, 2016
Viewed 438 times since Tue, Mar 14, 2017
2006 Cadillac XLR: Service Bulletin: Language Change for OnStar System (U.S. Only)
Viewed 598 times since Tue, Dec 20, 2016
Viewed 618 times since Sun, Dec 18, 2016
Viewed 891 times since Sun, Dec 25, 2016
Viewed 925 times since Sun, Dec 25, 2016
2006 - 2009 Cadillac XLR XLR-V: Service Bulletin: #PIP4112Q: Normal Characteristic - Sag Or Hesitation On Acceleration
Viewed 900 times since Sun, Dec 18, 2016
