#PIC3021: 2004-2005 Cadillac XLR Poor or No GPS reception - kw antenna accessory body cable display electrical inoperative map module navigation radio UM8 - (Jun 24, 2004)
Subject: 2004-2005 Cadillac XLR Poor Or No GPS Reception
The following diagnosis might be helpful if the vehicle exhibits the described symptoms in the PI.
Some customers may state that the Navigation radio will not show the proper location of the vehicle. When performing diagnosis, you may notice that the Navigation radio will have poor or no GPS reception.
Remove the Navigation radio and inspect the routing and securing of the GPS coax cable. The GPS antenna comes with a extra long coax cable. The extra coax cable should be looped into a circle and attached to the center HVAC case by the back of the radio. If the extra coax cable is bundle up and secured in the middle, like a bow tie, it can reduce the GPS reception. Repair as needed.
(2004-2005 Cadillac XLR)
Viewed 661 times since Fri, Dec 30, 2016
2005 - 2009 Cadillac XLR: TechLink Article: Noticeable Difference in Audio Volume Level
Viewed 535 times since Tue, Dec 20, 2016
2006 Cadillac XLR: Service Bulletin: Language Change for OnStar System (U.S. Only)
Viewed 477 times since Tue, Dec 20, 2016
2004 - 2009 Cadillac XLR: Bose Sound System
Viewed 909 times since Tue, Dec 20, 2016
2005 - 2008 Cadillac XLR: TechLink Article: Fob Conditions
Viewed 495 times since Tue, Dec 20, 2016
2004 - 2009 Cadillac XLR: Service Bulletin: IPC Odometer Programming Method Quick Reference Guide
Viewed 611 times since Sun, Dec 18, 2016
Viewed 320 times since Tue, Mar 14, 2017
Viewed 743 times since Sun, Dec 25, 2016
Viewed 348 times since Tue, Mar 21, 2017
