2004 - 2005 Cadillac XLR: Campaign: Exterior Lighting - Turn Signal Malfunction
MAKE/MODELS: MODEL/BUILD YEARS:
Cadillac / XLR 2004 - 2005
MANUFACTURER: General Motors Corp.
NHTSA CAMPAIGN ID NUMBER: 06V263000 MFG'S REPORT DATE: July 12, 2006
COMPONENT: Exterior Lighting: Turn Signal
POTENTIAL NUMBER OF UNITS AFFECTED: 7689
SUMMARY:
On certain passenger vehicles, the Daylight Running Lights (DRL), turn signal, and parking lamps use the same bulb. The bulb may become damaged from vibration within a loose fitting socket or air entering the bulb due to an inadequate seal. Both of these conditions will cause the bulb to burn out prematurely.
CONSEQUENCE:
If this were to occur, the driver would notice that the arrow in the instrument panel would flash faster than normal when the turn signal is activated. The loss of the DRL and turn signals could fail to warn others of the driver's presence or intentions and could lead to a vehicle crash.
REMEDY:
Dealers will replace the socket and bulb in both lamps free of charge. The recall began on July 31, 2006. Owners may contact Cadillac at 1-866-982-2339.
NOTES:
General Motors Recall No. 06013. Customers may also contact The National Highway Traffic Safety Administration's Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to http://www.safercar.gov.
Viewed 1085 times since Sun, Dec 25, 2016
Viewed 761 times since Tue, Mar 14, 2017
Viewed 516 times since Tue, Mar 14, 2017
Viewed 802 times since Tue, Dec 20, 2016
2007 - 2009 Cadillac XLR: Service Bulletin: #PIC4510C: OnStar® TBT (Turn by Turn) And Digit Display Location - (Jul 18, 2012)
Viewed 848 times since Sun, Mar 19, 2017
Viewed 766 times since Sun, Dec 25, 2016
2009 Cadillac XLR: GM TechLink Article: EBCM Condition
Viewed 775 times since Tue, Dec 20, 2016
Viewed 1139 times since Sun, Dec 25, 2016
Viewed 952 times since Tue, Dec 20, 2016
Viewed 567 times since Tue, Mar 21, 2017
