Date: September 28, 2006
Subject: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71
Models: 2005-2007 Cadillac XLR and XLR-V
2005-2007 Chevrolet Corvette
Intermittent Service Stability Message on the DIC with ONLY DTC C0561 Symptom 71 set in history or current. This is the result of a software concern within the EBCM
Revised EBCM software is under development. Replacement of the EBCM or BCM will not correct this condition. Revised software should be available in November 2006.
Viewed 184 times since Wed, Mar 22, 2017
Viewed 427 times since Tue, Jan 10, 2017
2004 - 2009 Cadillac XLR: Service Bulletin: Diagnostic Tip - Difficulty Programming Modules, Cannot Achieve Ignition On, Engine Off Mode
Viewed 190 times since Sun, Dec 18, 2016
Viewed 127 times since Tue, Mar 21, 2017
Viewed 208 times since Sun, Dec 25, 2016
2007 - 2009 Cadillac XLR: Service Bulletin: #PIC4510C: OnStar® TBT (Turn by Turn) And Digit Display Location - (Jul 18, 2012)
Viewed 91 times since Sun, Mar 19, 2017
2004 - 2005 Cadillac XLR: Campaign: Exterior Lighting - Turn Signal Malfunction
Viewed 273 times since Sun, Dec 25, 2016
Viewed 186 times since Sun, Dec 18, 2016
2004 - 2009 Cadillac XLR: Service Bulletin: Red LED and B2455 After Performing Canada Upgrade Bulletin 15-08-44-001
Viewed 185 times since Sun, Dec 18, 2016
