2004 Cadillac XLR: Service Bulletin: #PIP3233: 2004 Cadillac SRX and XLR 5L50E No Fourth or Fifth Gear
#PIP3233: 2004 Cadillac SRX and XLR 5L50E No Fourth or Fifth Gear Possible Codes P0700 P0741 P0762 - kw 3-4 shift 4-5 code DTC - (Nov 15, 2004)
Subject: | 2004 Cadillac SRX and XLR 5L50E No Fourth or Fifth Gear Possible Codes P0700 P0741 P0762 |
Models: | .2004 Cadillac SRX, 2004 Cadillac XLR |
- Vehicle will command the 3-4 and 4-5 upshift but no fourth or fifth gear is obtained. Possible DTC’s P0700, P0741, P0762 may or may not be present. The transmission may have metal debris in the pan.
- The direct clutch backing plate snap ring may have moved out of position. Currently, the direct clutch is not serviceable but will be in the near future. Repair as necessary.
- Models:
- (2004 Cadillac SRX) and (2004 Cadillac XLR)
