Below is the procedure for resetting the engine oil life monitor on the 2004 Cadillac XLR:
1. Press the up or down arrow to scroll the DIC to show OIL LIFE.
2. Once the XXX% ENGINE OIL LIFE menu item is highlighted, press and hold the RESET button until the percentage shows 100%. Repeat the steps if the percentage does not return to 100.
3. Turn the key to OFF.
If the Change Oil Now message comes back when you start the vehicle, the engine oil life system has not reset. Repeat the procedure.
- May 2003 GM TechLink
Viewed 947 times since Fri, Dec 30, 2016
2004 - 2005 Cadillac XLR: Service Information: No Crank, PRNDL Inoperative
Viewed 1124 times since Sun, Dec 25, 2016
Viewed 1139 times since Sun, Dec 25, 2016
2007 - 2009 Cadillac XLR: Service Bulletin: #PIC4510C: OnStar® TBT (Turn by Turn) And Digit Display Location - (Jul 18, 2012)
Viewed 848 times since Sun, Mar 19, 2017
2005 - 2009 Cadillac XLR: TechLink Article: Noticeable Difference in Audio Volume Level
Viewed 861 times since Tue, Dec 20, 2016
Viewed 705 times since Sun, Dec 18, 2016
2008 Cadillac XLR: Service Bulletin: Change in the GM Nav Disc Update Program
Viewed 938 times since Tue, Dec 20, 2016
2004 - 2005 Cadillac XLR: Campaign: Exterior Lighting - Turn Signal Malfunction
Viewed 904 times since Sun, Dec 25, 2016
Viewed 930 times since Tue, Dec 20, 2016
Viewed 765 times since Sun, Dec 18, 2016
