2004 - 2009 Cadillac XLR: Service Bulletin: #PIC4858A: Navigation Radio CD Error - CD Player Will Not Accept Discs - (Feb 11, 2013)
Subject Navigation Radio CD Error - CD Player Will Not Accept Discs
Models 2004-2009 Cadillac XLR
This PI was superseded to update the photos. Please discard PIC4858.
Some customers may comment that the CD changer (CDX) will not accept CD’s or the display shows a "CD Error" message when attempting to play a disc. This will usually occur after the radio or CD changer was recently serviced for a different customer's concern.  This may be caused because the ″shipping pin″ was not removed from the bottom of the CD changer prior to installing the service part into the vehicle.
2004 - 2009 Cadillac XLR Radio
Remove the shipping pin from the bottom of the CD changer prior to installing into the vehicle. This item is called out by an arrow in the first picture below.  The second picture shows the shipping plug that has already been removed from the CD changer.
If returning the Navigation radio to the Electronic Service Center, be sure to reinstall the shipping pin to prevent damage to the unit while in transit.
Viewed 686 times since Sun, Dec 18, 2016
Viewed 1107 times since Sun, Dec 25, 2016
Viewed 838 times since Fri, Dec 30, 2016
Viewed 705 times since Sun, Dec 18, 2016
Viewed 1539 times since Sun, Dec 18, 2016
Viewed 946 times since Fri, Dec 30, 2016
2004 - 2009 Cadillac XLR: Service Information: Head-Up Display Conditions
Viewed 1108 times since Wed, Dec 21, 2016
Viewed 516 times since Tue, Mar 14, 2017
Viewed 744 times since Sun, Dec 18, 2016
2008 Cadillac XLR: Service Bulletin: Change in the GM Nav Disc Update Program
Viewed 938 times since Tue, Dec 20, 2016
