2004 - 2009 Cadillac XLR: Service Bulletin: Diagnostic Tip - Difficulty Programming Modules, Cannot Achieve Ignition On, Engine Off Mode
#PIC3520C: Diagnostic Tip - Difficulty Programming Modules, Cannot Achieve Ignition On, Engine Off Mode - (Nov 2, 2015)
Subject: Diagnostic Tip - Difficulty Programming Modules, Cannot Achieve Ignition On, Engine Off Mode
Models: 2005 - 2011 Cadillac STS
This PI was superseded to update Model Years. Please discard PIC3520B.
Some technicians may experience failed module programming or difficulty performing certain diagnostic procedures due to the ignition not being in the "Ignition On, Engine Off" mode. The vehicles listed in this PI use a keyless access system with push button start.
To reach the "Ignition On, Engine Off" mode, press and hold the ACC/OFF portion of the Start/ACC/OFF mode button for 5 seconds with a valid keyless entry transmitter inside the vehicle and the transmission in Park (Auto Trans) or Neutral (Man Trans).
Viewed 878 times since Tue, Dec 20, 2016
Viewed 801 times since Tue, Dec 20, 2016
Viewed 761 times since Tue, Mar 14, 2017
Viewed 946 times since Fri, Dec 30, 2016
2007 - 2009 Cadillac XLR: Service Bulletin: #PIC4510C: OnStar® TBT (Turn by Turn) And Digit Display Location - (Jul 18, 2012)
Viewed 848 times since Sun, Mar 19, 2017
Viewed 686 times since Sun, Dec 18, 2016
Viewed 791 times since Tue, Dec 20, 2016
Viewed 1085 times since Tue, Dec 20, 2016
Viewed 765 times since Sun, Dec 18, 2016
Viewed 1107 times since Sun, Dec 25, 2016
