Subject: | IPC Odometer Programming Method Quick Reference Guide |
Models: | 2017 and Prior GM Passenger Cars and Trucks |
Attention: | This Bulletin applies to vehicles sold in the U.S. and Canada Only. |
This Bulletin has been revised to update the Chevrolet Aveo and Pontiac G3 information. Please discard Corporate Bulletin Number 07-08-49-020K.
The purpose of this bulletin is to provide a reference guide to help identify which season odometer programming method to use after replacing the instrument panel cluster (IPC). The three season odometer programming methods in use today are listed below. In addition, this reference guide lists the component where the season odometer value is stored. The season odometer value may be stored in the IPC, the driver information center (DIC) or the integrated body control module (IBCM), also commonly called a body control module (BCM).
Season Odometer Programming Methods in Use Today
- IPC reprogramming and setup using the service programming system (SPS).
- Odometer setup at the electronic service center (ESC) when using an exchange IPC/DIC.
- Tech 2® – The Tech 2 is used to set up a replacement BCM, which includes loading the odometer value that is displayed and stored in the IPC. A replacement IPC will display the previously stored vehicle odometer value, communicated from the BCM, after cycling the ignition or driving the vehicle.
*The odometer programming is integrated as part of the BCM programming procedure. It is not a stand-alone event.
Note: Stable battery voltage is critical during programming. Any fluctuation, spiking, over voltage or loss of voltage will interrupt programming. When required install the EL-49642 SPS Programming Support Tool to maintain system voltage. If not available, connect a fully charged 12 V jumper or booster pack disconnected from the AC voltage supply. DO NOT connect a battery charger.
Model |
Model Year |
Odometer Value Storage |
Odometer Programming Method |
Buick |
Cascada |
2016-2017 |
BCM |
SPS* |
Century |
2003-2005 |
IPC |
ESC |
Enclave |
2008-2017 |
IPC |
ESC |
Encore |
2013-2017 |
BCM |
SPS* |
Envision |
2016-2017 |
BCM |
SPS* |
LaCrosse/Allure |
2005-2009 |
IPC |
ESC |
LaCrosse |
2010-2017 |
BCM |
SPS* |
Lucerne |
2006-2011 |
IPC |
ESC |
LeSabre |
2003-2005 |
IPC |
ESC |
Park Avenue |
2003-2005 |
IPC |
ESC |
Rainier |
2004-2007 |
IPC |
SPS |
Regal |
2003-2004 |
IPC |
ESC |
2011-2017 |
BCM |
SPS* |
Rendezvous |
2003-2007 |
IPC |
ESC |
Terraza |
2005-2007 |
IPC |
ESC |
Verano |
2012-2017 |
BCM |
SPS* |
Cadillac |
ATS |
2013-2017 |
BCM |
SPS* |
CTS |
2003-2007 |
IPC |
ESC |
CT6 |
2016–2017 |
BCM |
SPS* |
CTS Coupe, CTS Wagon, CTS-V |
2008–2013 |
IPC |
ESC |
CTS Sedan, CTS-V |
2014–2017 |
BCM |
SPS* |
DeVille |
2003-2005 |
IPC |
ESC |
DTS |
2006-2011 |
IPC |
ESC |
ELR |
2014–2016 |
BCM |
SPS* |
Escalade |
2003-2014 |
IPC |
SPS |
Escalade |
2015-2017 |
BCM |
SPS* |
Seville |
2003-2004 |
IPC |
ESC |
SRX |
2004-2009 |
IPC |
ESC |
2010-2016 |
IPC |
SPS* |
STS |
2005-2011 |
IPC |
ESC |
XLR |
2004 - 2009 |
IPC |
ESC |
XTS |
2013-2017 |
BCM |
SPS* |
XT5 |
2017 |
BCM |
SPS* |
Chevrolet |
Astro |
2003-2005 |
IPC |
ESC |
Avalanche |
2003-2013 |
IPC |
SPS |
Aveo |
2004-2008 |
IPC |
ESC |
2009-2011 |
IPC |
SPS |
Blazer |
2003-2005 |
IPC |
ESC |
Bolt EV |
2017 |
BCM |
SPS* |
Colorado |
2004-2011 |
IBCM |
Tech 2 |
Colorado |
2012-2017 |
BCM |
SPS* |
Camaro |
2010-2017 |
BCM |
SPS* |
Captiva Sport |
2012-2013 |
IPC |
SPS |
Cavalier |
2003-2005 |
IBCM |
Tech 2 |
City Express |
2016–2017 |
BCM |
SPS* |
Cobalt |
2005-2010 |
IBCM |
Tech 2 |
Corvette |
2003-2013 |
IPC |
ESC |
2014–2017 |
BCM |
SPS* |
Cruze |
2010-2017 |
BCM |
SPS* |
Epica |
2004-2006 |
IPC |
ESC |
Equinox |
2005-2006 |
IBCM |
Tech 2 |
2007-2009 |
IPC |
ESC |
2010-2017 |
BCM |
SPS* |
Express |
2003-2017 |
IPC |
ESC |
HHR |
2006-2011 |
IBCM |
Tech 2 |
Impala Limited (VIN W) |
2003-2016 |
IPC |
ESC |
Impala (VIN 1) |
2014–2017 |
BCM |
SPS* |
Kodiak |
2003-2009 |
IPC |
ESC |
Malibu |
2003 |
IPC |
ESC |
2004-2011 |
IBCM |
Tech 2 |
2012-2017 |
BCM |
SPS* |
Monte Carlo |
2003-2007 |
IPC |
ESC |
Optra |
2004-2007 |
IPC |
ESC |
Orlando |
2011-2014 |
BCM |
SPS* |
S-10 |
2003-2004 |
IPC |
ESC |
Silverado Classic |
2003-2007 |
IPC |
SPS |
Silverado HD |
2007-2017 |
IPC |
SPS |
Silverado LD |
2007-2013 |
IPC |
SPS |
2014–2017 |
BCM |
SPS* |
Sonic |
2012-2017 |
BCM |
SPS* |
Spark |
2013-2017 |
BCM |
SPS* |
SS |
2014–2017 |
BCM |
SPS* |
SSR |
2003-2006 |
IPC |
ESC |
Suburban |
2003-2014 |
IPC |
SPS |
Suburban |
2015-2017 |
BCM |
SPS* |
Tahoe |
2003-2014 |
IPC |
SPS |
Tahoe |
2015-2017 |
BCM |
SPS* |
TrailBlazer |
2003-2009 |
IPC |
SPS |
Traverse |
2009-2017 |
IPC |
ESC |
Trax |
2013-2017 |
BCM |
SPS* |
Uplander |
2005-2009 |
IPC |
ESC |
Venture |
2003-2005 |
IPC |
ESC |
Volt |
2011-2017 |
BCM |
SPS* |
GMC |
Acadia |
2007-2016 |
IPC |
ESC |
Acadia Limited |
2017 |
IPC |
ESC |
Acadia |
2017 |
BCM |
SPS* |
Canyon |
2004-2011 |
IBCM |
Tech 2 |
2012-2017 |
BCM |
SPS* |
Envoy |
2003-2009 |
IPC |
SPS |
Jimmy |
2003-2005 |
IPC |
ESC |
Safari |
2003-2005 |
IPC |
ESC |
Savana |
2003-2017 |
IPC |
ESC |
Sierra Classic |
2003-2007 |
IPC |
SPS |
Sierra HD |
2007-2014 |
IPC |
SPS |
Sierra HD |
2015-2017 |
BCM |
SPS* |
Sierra LD |
2007-2013 |
IPC |
SPS |
2014–2017 |
BCM |
SPS* |
Sonoma |
2003-2004 |
IPC |
ESC |
Terrain |
2007-2009 |
IPC |
ESC |
Terrain |
2010-2017 |
BCM |
SPS* |
TopKick |
2003-2010 |
IPC |
ESC |
Yukon |
2003-2006 |
IPC |
SPS |
2007–2014 |
IPC |
SPS |
2015-2017 |
BCM |
SPS* |
HUMMER |
H2 |
2003-2007 |
IPC |
SPS |
2008-2010 |
IPC |
ESC |
H3 |
2006-2010 |
IBCM |
Tech2 |
Oldsmobile |
Alero |
2003-2004 |
IPC |
ESC |
Bravada |
2003-2004 |
IPC |
SPS |
Silhouette |
2003-2004 |
IPC |
ESC |
Pontiac |
Aztek |
2003-2005 |
IPC |
ESC |
Bonneville |
2003-2005 |
IPC |
ESC |
G3 |
2009-2010 |
IPC |
SPS |
G5 |
2007-2010 |
IBCM |
Tech 2 |
G6 |
2005-2009 |
IBCM |
Tech 2 |
G8 |
2008-2009 |
IPC |
SPS |
Grand Am |
2003-2005 |
IPC |
ESC |
Grand Prix |
2003-2008 |
DIC |
ESC |
GTO |
2004-2006 |
IPC |
ESC |
Montana |
2003-2005 |
IPC |
ESC |
Montana SV6 |
2005-2009 |
IPC |
ESC |
Pursuit |
2005-2006 |
IBCM |
Tech 2 |
Solstice |
2006-2010 |
IBCM |
Tech 2 |
Sunfire |
2003-2005 |
IBCM |
Tech 2 |
Torrent |
2006 |
IBCM |
Tech 2 |
2007-2010 |
IPC |
ESC |
Vibe |
2003-2010 |
IPC |
ESC |
Wave |
2005-2008 |
IPC |
ESC |
Saab |
9-7X |
2005-2009 |
IPC |
SPS |
Saturn |
ASTRA |
2008-2009 |
IPC |
SPS |
AURA |
2007-2009 |
IBCM |
Tech 2 |
ION |
2003-2007 |
IBCM |
Tech 2 |
L-Series |
2003-2005 |
IBCM |
Tech 2 |
OUTLOOK |
2007-2010 |
IPC |
ESC |
RELAY |
2005-2007 |
IPC |
ESC |
SKY |
2007-2010 |
IBCM |
Tech 2 |
VUE |
2003-2007 |
IBCM |
Tech 2 |
2008-2010 |
IPC |
SPS |
