XLR Net Knowledgebase v1.0
2004 XLR: Resetting the Engine Oil Life Monitor
User Opinions (0 votes)
No users have voted.
Helpful
Not helpful
1. Press the up or down arrow to scroll the DIC to show OIL LIFE.
2. Once the XXX% ENGINE OIL LIFE menu item is highlighted, press and hold the RESET button until the percentage shows 100%. Repeat the steps if the percentage does not return to 100.
3. Turn the key to OFF.
If the Change Oil Now message comes back when you start the vehicle, the engine oil life system has not reset. Repeat the procedure.
- May 2003 GM TechLink
Visitor Comments
Post Comment for "2004 XLR: Resetting the Engine Oil Life Monitor"
   Your Name:
   Email Address:
* Your Comment:
* Enter the code below:
Related Questions
No attachments were found.
Continue
