Search the Knowledgebase |
Browse by Category |
| 2004 - 2008 XLR and XLR-V: TechLink Article: "Shift to Park" Message |
| User Opinions (0 votes) |
No users have voted.
On some 2004-08 Cadillac XLR and V models, the Driver Information Center (DIC) may display a "Shift To Park" message when the vehicle is in Park, or the Auto Door Lock/Unlock features may be inoperative. Also, the ignition mode switch may not go to the Off position.
One of these may be the cause.
1. Improperly adjusted shifter cable -- Adjust the shift cable in the Park position. Place the shifter in the Park position, lift the vehicle and rotate the rear wheels to verify that the park pawl is engaged (wheels will not move). Release the cable adjustment lock and allow the cable to relax. Re-seat the cable adjustment lock. Refer to SI document 927794 if needed to verify shift cable adjustment procedures.
2. Secondary park switch circuit concern -- Check the status of the Internal Mode Switch in the Transmission Control Module (TCM). If the TCM is indicating the correct gear, check the secondary park switch located on the right side of the shifter assembly. This switch is a direct input into the Body Control Module (BCM). This data can be viewed by following the Tech 2 path below.
3. Secondary park switch concern -- If the secondary park switch shows Park via Tech 2 data, re-check the shift cable adjustment and make sure the shifter button is not stuck. If both items check OK, replace the shifter assembly. At present, the switch is not available separately.
- Thanks to Dino Poulos June 2008 - GM TechLink
Tech 2 Path for 2004-06 |
Diagnostics > Select Model Year 2004, 2005 or 2006 > Passenger Car > (6) Cadillac > Y > Vehicle Control Systems > Computer Integrating Systems > Data Display > Body Control Module > Data >Parameter #16 "Park Switch Auto" |
Tech 2 Path for 2007-08 |
Diagnostics > (7) 2007 > Passenger Car > (6) Cadillac > Y > Body > Body Control Module > Data Display > BCM Data > Parameter #16 "Park Switch Auto" |
| Visitor Comments |
| Attachments |
No attachments were found.
