XLR Net Knowledgebase v1.0
2005 - 2007 XLR/V: Service Bulletin: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71
User Opinions (4 votes)
100% thumbs up 0% thumbs down
Helpful
Not helpful
Date: September 28, 2006
Subject: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71
Models: 2005-2007 Cadillac XLR and XLR-V
2005-2007 Chevrolet Corvette
Condition/Concern:
Intermittent Service Stability Message on the DIC with ONLY DTC C0561 Symptom 71 set in history or current. This is the result of a software concern within the EBCM
Recommendation/Instructions:
Revised EBCM software is under development. Replacement of the EBCM or BCM will not correct this condition. Revised software should be available in November 2006.
Visitor Comments
Post Comment for "2005 - 2007 XLR/V: Service Bulletin: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71"
   Your Name:
   Email Address:
* Your Comment:
* Enter the code below:
Related Questions
No attachments were found.
Continue
