Search the Knowledgebase |
Browse by Category |
| 2004 - 2006: Service Bulletin: Diagnostic Trouble Code (DTC) C0710 Steering Wheel Position Sensor (SWPS) Signal, Service Stability System Message on Driver Information Center (DIC) |
| User Opinions (6 votes) |
100%
0%
Service Bulletin #: 06-02-35-002
Date: January 2006
Subject: Diagnostic Trouble Code (DTC) C0710 Steering Wheel Position Sensor (SWPS) Signal, Service Stability System Message on Driver Information Center (DIC) (Inspect and Secure Wires in SWPS Connector)
Model(s): 2004 - 2006 Cadillac XLR 2005 - 2006 Chevrolet Corvette with Steering Wheel -- Tilt, Telescoping (RPO N37) Attached below is the PDF document for this service bulletin.
| Visitor Comments |
